tilt and trim not working
Old 09-22-05, 04:23 PM
boat329
1991 Glastron Merc 350
tilt and trim not working ????
had the throttle cable replaced and I know speedometer no longer works??
Could it effect tilt/trim?
Old 09-22-05, 04:47 PM
The speedometer works on pressure, has nothing to do with the control box or the trim. Chech for a pinched or split hose. Is the trim switch located on the control box handle? Might have pinched wire while replacing cable.
Old 09-27-05, 08:22 PM
gimpie25
check if your trim/tilt wire are not disconnected and check for power to your motor. Did it work before?
