OMC question
alanstorie's Avatar
04-09-06, 06:56 AM   #1
OMC question
I have a OMC cobra outdrive on my boat powered by a chevy 350, The drive will not go in to forward, but it will go in to reverse -- I have taken the cable that goes to the drive off the linkage and even tried to do it manually, but same thing... I just get reverse Does anyone have experience with this kind of drive ( 1989 ) or had the same problem? Is there any kind of adjustment that I can try on the drive itself? any help well be appreciated ---- from another fourm some guy said that it might be a cable that was stretched...... anyone ever had this problem?
Thanks Alan
Pwrbait's Avatar
05-25-06, 07:22 PM   #2
Pwrbait
Did you try manually down on the outdrive itself with the shift lever? If it still does not go into forward, I'd say you probably broke a shift dog. It a tab of metal down on the shift lever that allows the forward/reverse gears to engage. Pretty common problem, and not terrible expensive to repair.
Chris
