starting and running motor without stern drive
Old 05-07-06, 02:35 PM
SilverGA2001
Question starting and running motor without stern drive
Hi,
I'm working on my boat, it's a '73 Century with a 3.0 Mercruiser inboard/outboard. Right now the lower housing and the gear housing are off the boat being looked over. I'm wanting to get the engine started though. Is there a way to feed water into the bell housing on the back to feed cooling water to the motor? Like sticking a hose on low pressure into one of the openings in there? Any ideas? I don't want to run it long, but would like to make sure it still fires and idles after the work.
Thanks.
Old 05-25-06, 07:04 AM
Pwrbait
Sure you can do it. The best way is to find the feed in the bell housing for the r/w and hook the hose to it, if you can't find or have access to it, remove the impeller out of your r/w pump to prevent burn up and monitor your engine temperature.
Chris
Old 06-04-06, 08:43 AM
harveje's Avatar
If the whole out drive is off you can buy / make a plate that covers the water inlet area on the bellhousing, it bolts to it and uses the o ring as a seal.
