boat trailering
Old 07-28-06, 11:55 AM
daswede's Avatar
boat trailering
I have a 16' boat with a stern drive. Whats the proper way to tow the boat,stern drive up,down,somwhere in between?
Thanks
Old 07-28-06, 12:37 PM
Thanks
Depending on your boat height on the trailer, keeping the drive up will keep you from damaging the lower unit. On the other hand, keeping the drive in the lowered position takes strain off the hydraulic system.
Old 07-28-06, 12:47 PM
daswede's Avatar
i'll check out how low i can lower the drive without endagering the lower unit traveling.
Thanks
Old 07-28-06, 06:52 PM
Tow the boat with the drive in the up position then use trailering supports that snap onto the trim rams, lower the drive down to the trailering supports....voila, now the drive is in the up position with no weight on the hydraulic system (this is assuming you have a stern drive that utilizes a hydraulic trim system, if you have an older OMC stringer drive, this would not apply since there is no hydraulic system for trailering).
When the boat is sitting for a prolong period, I recommend lowering the drive unit (less weight on the hydraulics, and the bellows are not stretched for the time the boat is sitting).
no adds
MM
Old 07-29-06, 06:22 AM
daswede's Avatar
Thanks for the tip. I'll check out the stern drive position this week-end.
