Looking for info on motor flushing
tvshooter's Avatar
ME
09-26-06, 09:14 AM   #1
I have a Johnson 25hp outboard that I am preparing for winter storage. I am new to this and was looking for advice on flushing the engine. It has never been in salt water, but I am going to fog the engine and therefore need to learn how to use (I'm assuming) the earmuffs. There is a hose connection on the motor, near the water pump telltale. What do the earmuffs do exactly,and how long should I run the engine for while doing it this way?
Sharp Advice's Avatar
Admin, Forums Host & Manager
CAL
09-29-06, 08:41 PM   #2
Hello: tvshooter
Good idea to learn "flushing" even for engines not used presently in salt water.You may someday have a salt water capable boat.
The hose may be for engine flushing. But may only flush the engine and not the water system from the pump up. So use the ears.
Ear muffs clamp around prop shaft housing where the water intakes are. Once on with water hose connected, turn on water FIRST then start engine.
Be sure water flows out of "P" hole beneath engine. Allow engine to run about 3-5 minutes. But DO NOT run engine above idle speed. Not enough water from flush ears to cool engine.
The rest of the needed info in the sticky note in this forums topic. Read it and/or copy and re past it into note pad and/or word. Then print it and save it. Read and use it for info.
Regards, Good Luck & Safe Boating. Sharp Advice. Boating Enthusiast. Web Sites Host, Forums Monitor, Manager, Moderator Hiring Agent & Multiple Topics Moderator.
Winterizing info:
http://forum.doityourself.com/showthread.php?t=146226
Stern Drive Help With Illustrations:
http://www.sterndrive.com
http://www.sterndrive.info
DIY'S Boat Pages:
http://doityourself.com/boats/index.shtml
Regards and Good Luck.
Web Site Admin, Moderator Hiring Agent, Host and Forums Manager. Energy Conservation Consultant & Natural Gas Appliance Diagnostics and Repair Technician. Fast, Fair, Friendly and Highly Proficient...
Don't Take Freedom For Granted. Thank A Veteran. Need an Employee? Hire a Veteran
Not only is a mind a terrible thing to waste, it's like a parachute.
It doesn't function until it's OPEN.........
Elvis. "The Sun Never Sets On A Legend."
Gun safety is using BOTH hands!
Driving Safety Reminder:
Buckle Up & Drive Safely.
"The Life You Save, May Be Your Own."
tvshooter's Avatar
ME
09-30-06, 09:04 AM   #3
Thank you so much for the info. Another reason I am asking about the hose connection is that I want to "fog" the engine and just wanted to make sure I'm doing it right. The engine has to be running to apply the fog, and obviously I need the water running through it. Have you ever fogged yours?
CAL
10-06-06, 11:30 AM   #4
Hello: tvshooter
Fogging?
Only fogging I have ever done is to mosquitoes...
Annoying, pesky, buzzing & bitting little critters!!!...
Not even sure why fogging would be needed. Following mfg's recommendations, standard procedures used in your area and normal routine checks should all that is needed and or required.
Checkout the provided link info and info in the link to sticky note in this topic. Note contains SOP (Standard Operating Practices/Procedures) found in all marine/boat magazines, etc.
Sincerely,
Sharp Advice.
Web Site Host, Forums Manager, Moderator Hiring/Promotions Agent & Multiple Topics Moderator. TCB4U2B2B Web Site Business Management Services.
