Removing the head on a mercruiser
I am planning to remove the risers and manafolds on my mercruiser 454. Then i need to remove the head as i am sure I have afew bad valves. I did a compression test, the pressure in #1 cylinder was 120psi
#3 0 psi #5 30 psi #7 60 psi. the starboard side was fine at 120 psi all cylinders. I then plan to send the head out to be repaired.
The boat is a 1995 searay with 440 hours on the motor. I maintain the boat myself and it has always been kept up. It's been many years since I removed a head ( 1974 on a 427 corvette ) and I just wanted to know if anyone out there had done this and if there was anything I should watch out for. My main concern is the snapping of bolts and having something drop into the motor when the intake manifold comes off. I have a SELOC book to go by. When I do I need to remove the rocker assemblies before I send the head out ?
Sounds as if it is possible you have a blown head gasket around the number 3/5 cylinders.... However - if you want to proceed with the head/valve work.....
As that Mercruiser is nothing more than a Chevrolet automobile engine with some aftermarket marine parts - you should be fine doing it the same way you did your 427. Take your time, take notes during disassembly - a digital camera is great for before and after shots to remind you how something came apart. Make your workplace as user friendly as possible - removing the engine cover completely for access - and cleaning out the bilge before starting to make finding that dropped "whatsit" easier to find.
You can leave the rocker arms in place - a good machine shop will reinstall everything for you to proper specs. Also - if you're going to do one head - then this is the time to do the other.
Make sure you buy marine grade head gaskets for reassembly. I would also replace the manifold bolts - both intake and exhaust - especially if you operate in salt water. Also a good time to do a thorough check of your exhaust manifolds for corrosion. 10 years is typically the time to replace them -especially in a salt water environment.
Removing the head 454
the head has been on the block for ten years. Any tricks to get the head off without causing damage to it? Also if I mark the distributors position to the intake manafold before i take it out, when i reinstall it it should go back to the correct location, right ?
Just make sure you get all the head bolts/intake bolts/exhaust bolts out before trying to pry it off. I usually use a crowbar judiciously to break the head gasket seal loose - and the heads have always followed with no problem.
As far as the distributor - yes - mark it before you disassemble - and make sure your marks line up on the re-install.
