Skips
bigtdusky's Avatar
01-05-07, 07:42 PM   #1
Skips
I have a 89 175 Evinrude I am the orignal owner and I use this motor all year.
I recently starting having a problem when I accelerates above 3000rpms. Below 3000 rpms the engine run fine. I changed the plugs, coils and wires, fuel filter and water seperator. the problem did not go away.
During the test drive I notice that the problem would go away if I turned the engine off for a few second and started it up again. The engine would run wild as a cat.
Another time when it happen, I pushed the primer button in several times and the engine began to runs better. and now I have a warning horn sounding when I turn the key on engine off
One tech advise me to check the fuel pump pressure. it had 3psi. I changed the fuel pump any way it was the orignal one. Can anyone help with these problem?
Ed Imeduc's Avatar
MO
01-18-07, 08:57 PM   #2
Out of the box here . But have you looked at any of the rubber gas lines. I know first it the gas filter then the gas pump. I find next its the gas lines. I have had some where its like the inside of them gets soft.
