Changing oil in lower unit, plug wont go back in
Old 04-08-07, 01:42 PM
Unhappy Changing oil in lower unit, plug wont go back in
I tried to change the oil in my Evinrude 35 yesterday. I pulled the lower plug out and then the top plug. I noticed that the lower plug had a long smooth tip on it,,so I tried to put it back into the hole. Now the lower plug wont go back into the hole, something is stopping it from going back in.. What do I need to do to get the plug back in????? Help... I have an outboard that I cant use till this is done..thanks in advance.....ron.
Old 04-08-07, 09:29 PM
As you might know by now that was not the drain plug. Get a manual to see how to get it back together.
Old 04-09-07, 06:26 AM
Ok, thanks for that obvious note..I did get the book out and found out that I screwed up on that one..thanks
Old 07-19-07, 05:09 PM
lu plug
You probley have it figured out by now, but if not. Take off the bottom, make sure it's in neutral and find the hole. this is the linkage pin for fwd/revs.
