2005 Seadoo
Old 07-07-07, 08:03 AM
2005 Seadoo
Can I clean the rocks out of my Seadoo or do I need to have someone look at it?
Old 07-09-07, 03:00 PM
Rocks? Where?
If you're talking about in the impeller housing, you should be able to remove the intake grate and flush the housing out from the rear of the jet pump with a water hose. I should add that, typically, any pebbles small enough to make it through the grate will be pumped through the system and out the jet pump easily when it's running. That being said, I'm not sure what your problem is....
