Flywheel key on a Johnson 35hp outboard
Old 09-16-07, 08:46 AM
I have been told that I need to replace the sheared flywheel key on my 1982 Johnson 35hp outboard. If I take the bolt off the top can I get to the key or is it further down? Do I need a flywheel puller like on a car engine?
Old 09-16-07, 07:19 PM
You will have to pull flywheel to replace the key. Johnson uses a wooduff type key. You will most likey need a flywheel puller.
Old 09-27-07, 09:37 PM
Ed Imeduc's Avatar
Wink
If I recall right . There are bolt holes in the flywheel for the puller to bolt too
