1963 sea king-- omc?
ernest3203's Avatar
NY
03-26-08, 03:19 PM   #1
i have i believe a 1963 40 hp sea king mtr,mod #cg18805a and ser# 36x870617,can any one tell me what make the motor is,and the fuel to oil ratio,the boat mtr says 24to1 of #30 oil to 6 gal gas,would that hold true to the new tcw3 syn 2 cycle oil as well.thanks for any help
thezster's Avatar
03-26-08, 03:58 PM   #2
Those old engines need lots of lubrication to keep running smoothly... Keep the oil/gas ratio at 24:1
ernest3203's Avatar
NY
03-27-08, 05:46 AM   #3
does it matter if i use tcw3 syn oil or straight 30 oil,thanks for the info
thezster's Avatar
03-27-08, 07:00 AM   #4
I, for one, get leery of using sythetics on older engines. Valid concern?? Don't know to be honest. I'd stick with 2 stroke oil (not 30 wt) designed for 2 stroke mixing (plenty of brands still out there).
Greenguy1's Avatar
MI
03-28-08, 04:22 AM   #5
I would consult with an oil represenative, these new oils are much better than the oils that were in use when these engines came out, and if I were to make a decision I would go with the new oils at maybe a 32:1 ratio and keep an eye on the spark plug colors. You may be able to go to 40:1 or higher.
