boat problems
Old 07-04-08, 01:19 PM
boat problems
I need help fixing my boat. I have a 86 chev that a replaced the silanoid and the key switch because it keep reving. Now the wires keep getting hot. I have moved them all around. i can get the wires to stop geting hot but when i start it get keeps trying to start . even when it does start when i let go of the key after it starts it cuts off. what could make it stop runing when it starts
Old 07-06-08, 12:26 PM
??? Keeps revving? Do you mean the starter keeps spinning? Wires get hot? Which wires? Changes wiring - how so? Need more info.
I had a "mystery" issue with my starter recently - the starter kept spinning after the motor started (solonoid would not disengage)... For some reason, which I can't explain, I had to put on 3 different (new) solonoids before the problem went away.
