Need help with 1999 sea doo gtx limited
Old 09-30-08, 11:50 AM
My sea doo will reach about 40 mph then it starts to bog down. It will not run any faster. Runs fine up to 40 mph.
Old 09-30-08, 04:32 PM
I would start simple and put new spark plugs in it and look to be sure you don't have any obstructions in the intake grate or pump housing. Make sure none of the blades on the impeller are bent. After that I would do a compression test. Next would be to check the clearance between the impeller and pump housing.
Old 10-12-08, 05:55 AM
Carb issues is what it sounds like to me.
The carbs have an internal barrel style filter on each carb, on the side where the ful line connect to the carbs. These internal filters get clogged and restrict fuel flow. When you pull them out of the carb, they will have what looks like white hair in them.
