motor not running at full speed
Old 10-13-08, 07:11 PM
i have a 1968 johnson 20 hp.I had the carb rubuilt and it ran fine for awhile,now at full throttle it runs at about 1/4 speed.It will run at high rpm's when in neutral but when i put in forward it barley runs
Old 10-13-08, 08:25 PM
check your spark plugs if in dought replace them they are cheap.Also for water or other "stuff" in the fuel.
Old 10-15-08, 02:25 PM
I'm no expert but I had a Merc doing something simular. I had a air leak at the fuel tank connection and it couldn't draw enough gas under load with the throttle up. When you have the unit out try pumping the fuel ball to see if it;s hard or it runs better then. Could also be a dirty fuel filter. Good Luck TJ Hornet
