volvo penta duoprops
regalguy's Avatar
11-04-08, 04:55 PM   #1
I cannot get the "fish line cutter" housing or locking nuts off between the two props to change anodes. What is the secret?
Thanks, Regalguy
samuari's Avatar
MN
11-04-08, 06:14 PM   #2
If you are trying to remove the props the second prop requires a apecial tool to remove it. You could try to make one by taking a pipe that slides over the propshaft and cutting 3 slits in it to grab the nut.
regalguy's Avatar
11-05-08, 06:00 AM   #3
thank you samuari for the quick response. I will go to the nearest volvo dealer and grab one of these babies today !!
thanks again
regalguy
samuari's Avatar
MN
11-05-08, 05:48 PM   #4
Another thing you might want if you buy the tool is the adapter for gear lube, that way you can do it yourself. They are cheap and you can get the plastic pumps cheap as well.
Good luck
