engine hour meters
Old 01-23-09, 01:32 PM
engine hour meters
What would cause both Hobbs hour meters to stop working? I check the power and all seams to be OK. They have not worked in about 1 year. The gauges are Stewart Warner, analog display only 1020 hours displayed.
Old 01-23-09, 09:41 PM
Welcome to the forums!
Usually it's corrosion at the wiring connections. If they're connected with blue clamp-on connectors, cut them off and connect them with the proper spade terminals. If they already have spade or screw terminals, clean the connections with fine-grit sandpaper.
First, turn off the battery or pull off the positive battery cable.
Old 02-09-09, 12:56 PM
Handheld GPS
Ricks advice for getting your hour meter working is on the money.
Sometimes wires corrode inside the insulation also. You may need to check to make sure current is flowing to the hour meter after you clean the connection.
Handheld GPS
Old 08-12-09, 09:53 AM
Hobbs Hour Meter
Kismet,
I read your post of Jan 09 regarding the Hobbs hour meters.
I have exactly the same problem, except mine are dead at about 1400 hours.
I have verified power, correctly polarized, to the meter and verified a good connection at the meter.
The likelihood of both going out at the same time seems so strange on such a normally bullet-proof item.
Did you ever come up with a solution other than replacing them?
Ken
