CANADA
02-21-09, 01:21 PM
Power Head removal of 25 Hp Evenrude
I have a modele E25RETS 25hp year 1993
the water pump is not getting water to the head I suspected the thermostat so I removed it
Ran the engine with the cylinder head cover removed still no water reaching the power head
I connected the tap water up to the pump outlet pipe going to the head at just more then a water droplets water filled the hose and shot out of the tell tale hose
I want to remove the power head to see if the intake gromet is blocked and is restrecting the flow from the water pump does anybody no where I can down load a manul discribing how to remove the head
the water pump keyway is properly installed
sorry to be so long winded
