evinrude o/b problem
bassman763's Avatar
03-02-09, 11:31 AM   #1
I have a 1988 evinrude that will not accelerate unless I pump the bulb,push the throttle a little and then choke the motor while pushing the throttle --- once up to speed runs fine and then once I stop I have to repeat the process uggg. I tried a different tank, hose ,bulb and gas and same problem. I also disconnected hose between fuel pump and carbs turn key over and alot of fuel came through so can I assume that it is carbs and not filter or pump. I live in the cold country so boat is stored in winter and I thought maybe the fuel went bad and gummed up carbs although i put stabalizer in? I would like to know if it is carbs for sure ?Also is it hard to take carbs off and add a rebuild kit I have a clymer manuel but seems vague.
Any help is appreciated as I would like to get out this spring after being land stranded for 2 seasons already.thanks
goldstar's Avatar
OH
03-02-09, 11:54 AM   #2
It does sound like a gummed carb. There are a few good carb cleaners that can be fed through the fuel line, but most are just sales hype. If you can get a rebuild kit, NAPA and others sell a good carb cleaning soaking solution. As to degree of difficulty, I would probably rate it a 4 (scale of 1-10).
Woody
You can trust your car - and a whole lot more - to the man who wears a star.
badeyeben's Avatar
IL
03-03-09, 06:16 AM   #3
Always disconnect the fuel line or shut off fuel and run the carb dry. Especially in cold weather. A dry carb can not gum up. You can put stabilizer in the tank to keep the fuel good.
samuari's Avatar
MN
03-03-09, 05:16 PM   #4
I personally think engine tunner is by far the best carb cleaner I have found. I have tried a lot of cleaners in the past 15 years and once i found OMC or BRP engine tunner I buy it by the gallon. We have a ultrasonic cleaner at work but I still use engine tunner.
It does sound like dirty carbs and if it has been sitting for more than a year it's a real good idea to clean them.
Have you changed spark plugs?
