Johnson 150 OB 2 stroke
axis's Avatar
03-03-09, 03:50 PM   #1
Was out in the boat today. Was traveling about 30 mph. The motor continued to rev but lost forward thrust power. It would run at lower speeds but when it exceeded say 2500 rpm it would rev but loose its forward power. It is a 2001 Johnson OB. Never had this kind of problem. Didn't die. Also I would back the throttle off to low pm and it worked fine but, as soon as I got into the higher rpm, same problem. I would appreciate any help.
samuari's Avatar
MN
03-03-09, 05:25 PM   #2
If the prop blades hanen't been damaged I would remove the prop and inspect the hub. Look for round balls of rubber where the splined part of the prop is held in place to the blade part.
