no water coming out at pee hole
Old 03-28-09, 11:19 PM
Mercury 50 hp 4 cyl. about a '74 model
I changed the impellar myself for the first time. It was hard getting the impellar into the housing..but it's in. I don't think you can put one in upside down...yes, I did turn it clockwise.
I'm not sure of the little 2" tubing that I had to slip back under the housing water pump, and under that little tubing was a little rubber o ring. Anybody live close to Gadsden, Al??
Any suggestions?
Thanks
Old 03-29-09, 05:36 AM
Not that its model related , I have a 77 Merc 500 (50hp).. but is this first startup after sitting a while ? Twice I had the tattletale-hole no water scare. Both times it was some kind of bug/etc that had crawled up the nozzle and plugged it. Try squeezing the nozzle around, maybe probe into it with something , but dont get too agressive with a small screwdriver or etc.. if its a bug it wont be too far up the pipe.
Hope it helps.
Old 03-29-09, 09:05 PM
I agree about the pluged tel-tale I use compressed air.
Old 03-30-09, 08:01 PM
Any suggestions?
Thanks
Just wondering when you changed the impeller did you reinstall the key way that locks the impeller on the shaft
Old 04-02-09, 05:01 PM
Yes...I put a little tiny bit of white multi-purpose grease (lubricant) to hold it on before sliding the impellar housing back down on it.
Old 04-02-09, 08:49 PM
I'm not familiar with that model, but does it have to worm up to open the thermostats before it will pee.
Old 04-02-09, 09:13 PM
No, it doesn't have to warm up and it doesn't have any thermostats.
Old 04-15-09, 07:52 PM
Tobypoo's Avatar
Had an issue with a motor that i had just purchased last year. Minimal water was flowing. When I took it to a mechanic, he advised that the water pump needed to be changed. $100 bucks later and she purred like a kitten.
Trackbacks are On
Pingbacks are On
Refbacks are On
