95 seadoo
digger2grt's Avatar
05-24-09, 07:30 PM   #1
95 seadoo
i have a 95 seadoo that will star great and run fine until the motor gets warm and then it falls off.Then it it falls on its face.It will pick up for a second and then fall off then pick up
samuari's Avatar
MN
05-24-09, 09:48 PM   #2
Welcome to the forums, I hope someone else will help out a bit as I don't have a whole lot of expirience with them.
Start with the basics
check compression
timing is fixed but once it's acting up check for spark it could be a coil.
Also check the fuel pump for tears in the diaphrams.
Rick Johnston's Avatar
NY
05-25-09, 04:02 AM   #3
Sounds like it could be vapor lock. Make sure the fuel lines are away from heat-producing parts of the engine. Also make sure there are no small cracks or other breaks in the fuel line, and that all connections are tight. Check the fuel filter, too.
