Boat Speedometer Ceased Functioning
Texas Mark's Avatar
06-26-09, 09:26 AM   #1
Recently purchased a used Sea Hunt that had been sporadically used and garage kept. On one of the first runs out, the speedometer was registering fine and after about 10 minutes it ceased to function and speed went to 0. I suspect the pitot may be plugged, but am not sure. Any advice on how to troubleshoot and possible causes?
stephen44's Avatar
VA
06-26-09, 12:28 PM   #2
Posted By: Texas Mark Recently purchased a used Sea Hunt that had been sporadically used and garage kept. On one of the first runs out, the speedometer was registering fine and after about 10 minutes it ceased to function and speed went to 0. I suspect the pitot may be plugged, but am not sure. Any advice on how to troubleshoot and possible causes?
i disconnect at speedometer end - should get stream of water out -if not the fault blockage is further back - disconnect pipe at engine - stream now ?
based on results you should be able to determine where fault is. I have success by blowing backwards with compressed air to clear - hope this helps
Stephen
chandler's Avatar
GA
06-26-09, 02:28 PM   #3
Or do as I did, sit there wondering why I had a very small leak along my right gunwale. A rat had chewed through the pitot tubing and it was dripping causing erratic speedometer readings. Double barb connector fixed it right up.
