beeping coming from dashboard
Old 07-25-09, 09:19 AM
I have a 2004 21 foot Rinker Captiva. It has a 260 horsepower 5 liter mercruiser inboard/outboard. I keep it up at Mark Twain Lake in Missouri. I took my boat to Table Rock Lake for a week of vacation and every time we take the boat out on the water an annoying beep keeps coming from the dash board. It appeared to be coming from the depth finder, but it still beeped when we turned the depth finder off. We have checked the fluids and added gear lube and it is still beeping. It beeps two times about every minute. It has never done this on Mark Twain Lake, but has been doing it the whole time on Table Rock Lake. Does anyone have any idea what this is?? It is driving us crazy! Thank you for your help!
Old 07-26-09, 03:45 AM
chandler's Avatar
Welcome to the forums! It probably is the depth finder. If it is doing it at speed, the pick up is being confused by cavitating water bubbles being churned up by the motor. Note your depth indicator at speed. If it is fluctuating greatly, then the depth finder can't give you an accurate measurement and it thinks it is in shallow water. You can turn off the audible beep on the unit, but I'm not sure what type you have, so you would have to drill down on the screen to do it. You could have it on fish find mode, and it is picking up the sonar of fish. There may be more fish in one lake than the other. There could be more structure in one lake than the other and that could fool the finder.
Old 07-26-09, 05:36 PM
Thank you so much for your help. The only thing that is confusing me is that the beep is not random. It beeps two times about every minute. It does it when we are moving and when the boat is just idling. We have been trying to play with the depth finder with no luck. Thanks again!
Old 07-26-09, 06:02 PM
If you have the 2" round gauge look for a bout a 1.5" round black horn. It will have a small red and black wire coming out of it.
It might be that the shallow alarm got reset.
Old 07-27-09, 03:03 PM
Thank you! I will check and see if that is the problem.
