228 mercruiser overheated
My 1979 Century 3000 with 305 chevy v8 228 mercruiser alpaha drive overheated yesterday. the water temp went up to around 220. I shut down, checked for obstructions on the intake ports on the outdrive, found none. Then I waited a while until the engine cooled. I started up and at slow speed started to go up the lake and the temp started rising again into the 200 range so I shut down and waited again. I started again and the temp dropped down to 150 and stayed there as if nothing had happened.
Now, I am afraid this will recur again.
Questions: first, any idea why the temp would act as it did?
should I replace the water pump now?
is there an audio alarm available, to supplement the temp gage, which I cant monitor all the time while pulling a skier etc.
thanks
Ed
thanks
Ed
It could be a stuck thermostat that eventually opened. It can't hurt to replace it.
Check the engine's water pump (not the drive's) for leaks and a loose pulley. Either symptom is a sign that the pump is failing.
Also, pull the boat and run it with ear muffs to make sure you have a good flow of cooling water coming from the outdrive. If you can't remember the last time the drive's impeller was replaced, it's probably time to do that as well.
