poppit valve
walleye_bill's Avatar
08-05-09, 01:18 PM   #1
poppit valve
can anyone explain to me where and how to acess the poppit valve on a 25 hp mercury tiller model outboard. its a 87 or 1988, and manual shows nothing of ot, or thermostat. thanks
samuari's Avatar
MN
08-05-09, 07:48 PM   #2
It is under a cover on the left or port side. The cover has 2 round portrusions (sp?)held on by 4 bolts. I think this is correct if you list your ser# I can look it up for sure. Sorry I didn't get back to you sooner but it's been a crazy week.
08-06-09, 04:19 AM   #3
ok
ill get serial posted. thanks pal
08-06-09, 05:44 PM   #4
serial #
its OD295058 for my 25 hp merc outboard
samuari's Avatar
MN
08-06-09, 08:38 PM   #5
I don't have my merc software at home but this is in your ser# range. It shows a thermostat referance # 37 but no popit valve.
So I would run the motor on a hose with the thermostat cover off to see if you have good water flow. If you do put your thermostat in a cup of hot water with a thermometer. the opening temp should be stamped on the stat.
If that all seams good I would check the gasket under the water pump and arround the housing. It's rare but I have seen a bad gasket will pump fine when under water but once the boat is on plane that part of the gearcase is out of the water and will suck air.
If I have time at work I will look up your ser# to be sure.
08-08-09, 07:00 AM   #6
thanks a ton
realy do appreciate all yer help.
samuari's Avatar
MN
08-09-09, 06:37 PM   #7
No problem I actually learn just as much as I help so keep me posted and we will get this.
I didn't get a chance to look up your specific ser# but does it look like the diagram?
08-09-09, 08:55 PM   #8
yes seems to look like it
wich number in the diagram is the poppit valve though.
samuari's Avatar
MN
08-10-09, 08:11 PM   #9
I'm sory It doesn't have one but it does have a thermostat #37.
08-12-09, 07:32 PM   #10
ahh
ok thanks ill open that up and have a look at her. ill keep u informed of my progress
