1986 Merc. stalls at low speed
Old 06-21-00, 09:24 PM
Marshall Buttrey
Post
I can't troll, and it's p----ing me off. At slow speeds it stalls constantly, and it often stalls when shifting into forward (if I leave it at low RPMs.) Idles great in neutral, runs great at anything above an idle, and easily starts after it stalls. I have heard of this problem with Mercs before, but never heard of a fix. Help Please.
Old 07-01-00, 11:55 AM
BoatMech's Avatar
Post
Ok we need the model to get specific
but the carbs are probably in need of some servicing. If its starts on the first crank
after stalling its probably just a little lean. where are you running, altitude?
when was the last service?
need the hp and model.. thanks
Old 07-01-00, 11:06 PM
Marshall Buttrey
Post
Thanks BOATMECH. I appreciate your response. Motor is 1986 35 HP. I don't believe altitude is a factor. I'm in middle Tennessee (Nashville), and I think the altitude is 490 ft. above MSL. I just purchased the boat in the spring. It is used, and I don't know when it was last serviced. I suspect it is running lean, but am a little nervous about playing with the mixture. I haven't even looked to see where the adjustment is. THANKS AGAIN
Old 07-05-00, 08:45 PM
BoatMech's Avatar
Post
There should be a little knob on the carb just above the venturi. give it a quarter turn counter clockwise. and then reasseble it and run it like usual. let me know if it helps.
Old 07-05-00, 09:12 PM
Marshall Buttrey
Post
Thanks BoatMech:
I'm planning to go out tomorrow, so I'll try it. Sounds easy enough. I'll let you know what I find.
Old 07-10-00, 12:06 AM
Marshall Buttrey
Post
Well I tried, maybe with a little success. I could tell no difference with a quarter turn. I turned the screw in all the way, then backed out 1 and a half turns. From there I turned it in until it started to run rough, then backed it out until it started to run rough. Then set it half way between. Itwas very difficult to tell anything when I backed the screw out, so I'm not sure. It does run better. How slow do I need to turn the screw? I think I might have been a little fast.
THANKS AGAIN
Marshall
Old 07-10-00, 05:27 PM
BoatMech's Avatar
Talking
Hey you did good!!
Thats the trick and it has to go kinda fast or it will stall.
each direction until it gurgles or coughs
and then back to the middle.
good work.
scott
Old 07-10-00, 11:24 PM
Marshall Buttrey
Post
Thanks Scott. I was out again today and it did okay. I really appreciate your help. The service offered by this site is excellent. Thanks Again.
Marshall
