Reverse stop working in 60hp merc outboard
ericamharper's Avatar
09-15-09, 07:19 AM   #1
We were out in the bay this past weekend and was slowly backing in reverse. We hit a rock and now the reverse is not working. We have a 60hp mercury outboard. We still have forward. Do you know what this may be and how to fix it?
printer-man's Avatar
09-16-09, 11:24 AM   #2
is the linkage still moving the shift lever all the way back?
if it is, are there any noises in the reverse position?
09-16-09, 11:51 AM   #3
The linkage seems to work fine and still will go in reverse with no noise. The prop doesn't spin but it revs up when you give it gas.
samuari's Avatar
MN
09-17-09, 09:56 PM   #4
Remove the drain plug from the lower unit and let a couple drips come out. If it is grey or metalic looking you have gear problems.
09-17-09, 10:31 PM   #5
We will try that..thank you very much!
