Batteries
gmacp's Avatar
10-14-09, 03:33 PM   #1
Battery question Please Help
I have a 17' boat, with a 235hp v6 outboard, I have 2 elec dwnrgrs, fishfinder and other electronics onboard. I have 1 lead acid bty & 1 deep cycle bty. how should i hook them up for optimum use, without using any switches, if possible? The deep cycle battery (megatron) is a good battery but does not last all day by itself.
Thanks!
GregH's Avatar
Super Moderator
CANADA
10-14-09, 04:32 PM   #2
I personally would keep the deep cycle and boat starting battery separate.
Just charge the deep cycle each day.
If you can not make a day on one battery then you would install enough battery capacity to do so.
Also, do you have a true deep cycle or do you have a marine multi-purpose battery.
A battery that is designed for starting and deep cycle will not work as well on deep cycle duty.
GregH.........HVAC/R Tech
samuari's Avatar
MN
10-14-09, 07:11 PM   #3
Welcome to the forums.
Greg is right don't hook deep cycle and starting batts together. The batts are made different and should be charged and used different.
What I would do is add another deep cycle and wire it in parelell as in red to red and black to black. This would double the time they last.
