zinc replacement
zinc replacement
I have a 2001 Johnson 150 O.B. 2 cycle. I am relacing the zincs. How do you replace the zinc inside the prop shaft? There are 2 bolts about 1/2 inch or so and one small bolt about 1/4 give or take. I didn't know there were zincs inside the prop shaft but upon inspection it appears to be eaten away pretty badly. I have replaced the 2 zincs that are on the underside and on the lower unit. Thanks for your help.
