Marine Upholstery
Marine Upholstery
What do you think is the strongest spray glue product to use for marine upholstery? I am a technician but I want to make sure that I am using the correct adhesive or glue to avoid problems in the future.
Welcome to the forums.
Curious ... what are you planning to use it for? Any spray glue works well to hold the foam to the back board while you staple plastic & vinyl.
If you're planning to use it as a replacement for staples, I haven't found a consumer product that works. Then again, I'm not a pro at marine upholstery -- just a DIYer with three boat interior refurbs under my belt.
