tilt and trim
Old 04-12-10, 08:08 AM
tilt and trim
i have a 69 fiberform 18' and cannot get the trim to work.ive changed the fluid,checked the motor,all good.any ideas?thanks
Old 04-12-10, 09:00 PM
What outdrive is on it, mercruiser or omc?
Does it do anything?
Can you hear the trim motor running in the up or down position?
Old 04-13-10, 04:39 AM
yes
yes can hear motor running in up and down.motor is a mercury 135 hp.
Old 04-13-10, 07:22 PM
If you remove the 2 bolts holding the motor to the pump assy and pull the motor up and out. There will be a small metal adapter between the motor shaft and the pump. I have seen these crack so the motor will spin and not move the input shaft of the hyd pump.
Trackbacks are On
Pingbacks are On
Refbacks are On
