removing a transom, what a job, any words of wisdom?
Old 06-10-10, 06:38 PM
I pulled the motor, removed the top caps and corner braces, got all the screws out, now the fun begins!
Half of the transom is mush, the other half is swolen. The mush side falls apart and wont give me enough grip to hook it and leverage the rest out. What a P.I.T.A, any words of wisdom? The swolen side won't move, the mush side is coming out a piece at a time.....somewhat..
Old 06-10-10, 07:16 PM
GregH's Avatar
Super Moderator
Pretty hard to offer advice without a detailed description of what you are working on.
By your description I might guess you are working on an aluminum boat?
Pictures would help.
You can put them on a free host like Photo Bucket and provide a link.
Old 06-10-10, 08:55 PM
Run a saw down in between the aluminum as long as you are sure you got everything out. It's still not going to be a easy job but it will be rewording once finished.
Old 06-11-10, 05:10 AM
I'm sure everything is out, it appears that it is swolen in the lower channel and on the right side channel. The left side is out, I probably have 12" removed top to bottom. I guess I was having dilusions of grandure when I thought that I would slide most of it out to use it for a pattern....LOL
Old 06-11-10, 06:49 PM
UPDATE: IT's OUT! I had to chew up about 1/3 of it with a wonder bar and a hammer removing a handful of wood at a time. After that I was able to hook the remainder and pull 2/3 out in one piece!
