Is there a reason why I have no ground wire to my aluminum hull?
HotRod53F100's Avatar
PA
06-17-10, 05:55 PM   #1
Everything in my boat has 2 wires and the grounds all connect together in the back. As an Electronics guy, I find it odd that there are no grounds connected to the aluminum hull. Is it just my boat or is there a reason for this? Sure would make it easier to add low powered stuff if I could connect to a common ground near the device.
samuari's Avatar
MN
06-17-10, 10:26 PM   #2
Your hull will corrode fast and you will end up with holes in it if you use it for a ground. I don't have the time right now to go into it further but just don't do it.
PA
06-18-10, 01:09 PM   #3
That's what I wanted, an expert opinion....THANKS! I'll skip the idea....
