Leaky Tracker
Old 06-24-10, 03:20 PM
Leaky Tracker
I have Tracker Pro Deep V16 aluminum. It leaks about 10-15 gallons per fishing day. Today I filled it with water on the trailer and watched. There are several rivets in the forward section that leak a little. I think I can mitigate that with some silicone. The worst rivet is accompanied by a small crack in the alum. Can I get away with a 2-3 sq in fiberglass patch? I just have no idea whether fiberglass will adhere to aluminum. Thanks for any good ideas out there.
Old 06-24-10, 08:26 PM
Sand the area with a real heavy grit paper like 36 and use a product called marine text. It's a real strong epoxy that will hold a lot better than silicone.
Old 06-25-10, 07:26 AM
I read your response
Is "marine text" the exact product name? I Googled it and nothing came up. I live in Boulder CO, which is a wasteland for power boat stuff. The closest marine dealers are 25-40 miles away in Denver. I'd like to buy on the internet. Thanks, you have helped me in the past.
Old 06-25-10, 08:55 PM
I was wrong it's marine tex. I have it as a filler on my gearcase that is below the water at over 90 MPH and it holds up fine. It real strong and made for under water use.
Old 06-28-10, 03:13 PM
Marine-Tex is great stuff, it looks and smells like JB weld when its mixed but I can vouch for its use. I fixed some holes in a 12' aluminum boat 5 years ago and it's still leak free. I also found that if you have seams that leak such as around the bottom of a transom, Gorilla Glue works wonders.
http://www.marinetex.com/
Old 06-28-10, 07:17 PM
GregH's Avatar
Super Moderator
I also have a leaky Tracker.
If you drill a very small hole at the end of the crack before you seal it you would prevent it from spreading.
