My Merc power cable looks bad, need your opinion
Old 07-06-10, 06:19 PM
My red power cable looks bad and probably should be replaced. I think that the cable may have laid in the water before I started to restore the boat. The insulation is bleached out almost white and some of it is coming off. It may be good under the sheath that houses all of the cables. It looks like goes right into the plug that hooks to the outboard and the plug appeard to be molded. I looked on Ebay but didn't see any replacements.
I have some 3M rubber vulcanizing tape that may fix it, but it may not be the best choice...your opinion?
Old 07-06-10, 08:28 PM
If the insulation is cracking replace it, corrosion will set in soon if it hasn't already.
Old 07-07-10, 06:22 AM
Corrosion has already set in, I can see it. Are these assembly something that is available or can I get in there and replace the red cable? The red wire is the battery cable and appears to be molded into the plug. If that won't come out then does it mean that i need all new controls?
Old 07-07-10, 09:19 PM
I'm guessing that the harness goes into the side of the motor. If it is I haven't worked on one of those but I bet you will need to buy the harness and it will have connectors for inside the control box.
Old 07-17-10, 02:13 PM
I had the same thing years ago. I used liquid tape and after it set up, covered that with electrical tape. I can't remember how long it's been since I did that, but the motors is 45 years old and the cable still does the job.
