Swivlease seat pedestal tip
Handyman663's Avatar
CO
07-13-10, 10:58 AM   #1
I asked more than a year ago how to remove the above pedestal from the base. Mine was seized. Someone suggested using a tie wrap to hold the locking lever in the open position and then whacking it with a rubber mallet. I finally tried it today. The tie wrap trick works great, although I think you could use a stainless hose screw clamp also. Definitely don't waste the $20 that I did for the tie wrap cinching tool. The tool didn't work and I could pull it tight enough with pliers.
Many whacks with a mallet failed to move it. Then I mixed a little water and detergent and poured in on the bushings. Voila, 5 whacks later it separated! I found sand grains between the bushing and base which may have been the culprit. Hope this helps someone out there.
samuari's Avatar
MN
07-13-10, 09:07 PM   #2
Cool!
Thanks man
