2 stroke verses 4 stroke ?????
rbgraber's Avatar
AR
07-27-10, 07:43 AM   #1
I had a mercury dealer tell me that a 2 stroke 90 HP is more powerful than a 90 HP 4 stroke. Is that true?
goldstar's Avatar
OH
07-27-10, 12:53 PM   #2
Ninety horsepower is ninety horsepower if rated by the same scale. However, the 4 cycle may have a better torque to horsepower ratio.
Woody
You can trust your car - and a whole lot more - to the man who wears a star.
stickshift's Avatar
WI
07-27-10, 01:11 PM   #3
Typically, the same size engine will have more hp in 2 stroke, but 90 hp is 90 hp
Will they tell you the torque figures? I knew a car salesman who summed it up, "horsepower ratings get people into the showroom but when they drive it, it's the torque which makes the sale."
rbgraber's Avatar
AR
07-27-10, 01:58 PM   #4
Thanks for the info.
I will ask what torque is?
Blair
Rick Johnston's Avatar
NY
07-28-10, 03:50 AM   #5
To say that one 90 HP motor has more torque than another 90 HP motor is somewhat misleading without knowing the RPM ranges over which the motors develop their horsepower.
Generally 4-stroke motors develop their rated horsepower at lower RPMs than their 2-stroke counterparts.
Another difference between 2-stroke and 4-stroke: Environmental. 4-strokes don't burn a mixture of gas & oil and tend to burn cleaner.
GregH's Avatar
Super Moderator
CANADA
07-28-10, 01:05 PM   #6
I agree that these HP ratings are quite misleading.
I just bought a new Mercury 3.5 hp 4 stroke for my canoe.
Had a choice of a 3.5 or a 2.5 hp, the 3.5 being $100.00 more.
I already knew exactly what the difference between the two was but asked the salesman anyway.
He said they put a bigger carb and tuned the 3.5 higher.
1 hp is not a lot of hp but it is a 40% increase over the 2.5.
In reality the engines use the same carb and have the same bore and stroke.
The reason one has a higher hp is that the 2.5 is rated at 5500 rpm and the 3.5 at 6000 rpm!
Pretty clever marketing I think!
What is even more clever is that all Merc engines under 25 hp are made by Tohatsu whose engines are less expensive.
GregH.........HVAC/R Tech
NY
07-29-10, 02:45 AM   #7
20 years ago we figured the difference between my Merc 170 and my friend's Merc 190: 2bbl carb vs 4bbl carb and his also had heavier lifter springs. Both were 4-bangers.
I could understand the carb, but springs?
