1967mercury 950ss outboard issues
Old 08-17-10, 08:13 AM
Hello I have recently, traded for a glastron swinger 17'6" tri hull. it came with a 1967 mercury 950 outboard on it, the guy I got it from replaced the water pump impeller, and now there is no forward or reverse, i'm assuming he did not realign the shaft when he reinstalled it , I am not a mechanic, but have some mechanical skills, how do I fix it to get the lower unit to shift ino gear ? any help would be greatly appreciated. thanks Patrick.
Old 08-18-10, 09:31 PM
Welcome to the forum.
Most likely the shift shaft didn't get lined up on top of the gearcase. Just remove the case down about 3", you will see the shift shaft in the front of the case.
Old 08-20-10, 11:41 AM
does it have to be in any certain gear
Old 08-20-10, 08:11 PM
This should help. http://forum.doityourself.com/marine...ower-unit.html
I do all mine in neutral to start.
Trackbacks are On
Pingbacks are On
Refbacks are On
