Plug wires, solid copper, spiral, buy a set, make your own?
HotRod53F100's Avatar
PA
05-30-11, 05:45 PM   #1
I found #2 plig wire broken about an 1" from the plug cap.
I have some automotive wire laying around but its spiral, which is better or does is matter? What about solid lawn mower spark plug wire, is that OK? Should I buy a kit and make them all new? Should I buy a pre-made kit? I have made them before for hotrods but I don't have the proper crimper for something like this. I know some come with a tool that goes in the vice and you beat on it.
What do ou think?
Rick Johnston's Avatar
NY
05-31-11, 03:33 AM   #2
Refresh me -- what engine's in that boat?
PA
05-31-11, 04:34 AM   #3
1977 Mecr 500 Thunderbolt serial starting with 48xxxxx
NY
06-01-11, 04:01 AM   #4
Copper, not carbon resistance. Basically the same thing you used on the 'rods.
PA
06-01-11, 06:06 AM   #5
If I had a roll of solid 7mm used on lawn tractors, I guess that is the same thing?? My hotrod has a 1977 small block Chevy and uses spiral wound, I have some real nice 8 mm red and 8 mm yellow, but that doesn't help.
3 of 4 coils look like the wire is permanent on the secondary side but I think the brass connector is just way up inside. The #2 wire looks like it has been fixed and the brass connecter was all boogered up, I had to straighten it out. I don't want to damage anything, so can I assume that I need to yank the plug wire out of the coil and there is no such thing as a permanently connected wire?
PA
06-01-11, 04:13 PM   #6
Wires made, found some 7 mm spark plug wire used on tractors. It's the same diameter and marked spark plug wire right on he jacket, now onto the nect issue in a new thread!
Thanks for your advice!
