HEATING
Old 01-13-01, 05:35 PM
G
Guest
I WOULD LIKE TO KNOW WHY IS IT THAT WHEN INSTALIING BASEBOARD HEATING NO BLEEDER VALVE IS REQUIRED THANK YOU FOR YOUR TIME
Old 01-14-01, 11:29 PM
BoatMech's Avatar
When using a closed cooling system to distribut heat
to the passengers in the vessel or to heat water in the
ships water heater it is only necessary to bleed off air when the heat exchanger used or any of its transfer lines
are above the point of the engines heat exchanger.
Come again.
Scott
