old gas in tank
Old 09-16-12, 01:20 PM
W
wwc
wwc is offline
old gas in tank
I didn't get my fishing boat out this year or last year ,it's a fish and ski outboard with the tank in the hull.
it has about a 1/8 tank, should i not worry since it has oil mixed with the fuel or next year fill it with fresh fuel and run it till it's all gone or is there a way to drain the fuel out, i tried to siphon but i couldn't get anything out.
Old 09-16-12, 03:12 PM
P
Received 1,772 Upvotes on 1,584 Posts
Best would be to remove the fuel as soon as possible to prevent varnish deposits from forming that can break loose and clog your carburetor(s). But, as you've found out, getting fuel out of a tank in the hull can be difficult. Siphoning fuel out can be difficult. I've used a vacuum pump intended for changing the oil of inboard engines. You can also disconnect the fuel line that goes the the engine and use it to draw the fuel out.
If you don't drain the fuel out I think you'd be OK if there is only 20% old fuel. 80% new fuel mix should dilute it enough that it will run. There is still that danger of varnish and other deposits though. You may get the engine started only to have it die as the crud shakes loose and causes trouble with the fuel filter and carburetor(s).
I'm most concerned about the condition of your engine and carburetor (s). Did you pickle or prepare the engine for long term storage? Did you run the gas out of the carbs. before putting it away?
Old 09-16-12, 08:18 PM
W
wwc
wwc is offline
thanks for the reply, Yes I did winterize the lower unit and fogged the carb and cylinders with the spark plugs out and rotated the pistons also .
Old 09-17-12, 04:24 AM
R
Received 1 Upvote on 1 Post
It gets a whole lot more interesting if that old gas contains ethanol. Phase separation is a huge problem with ethanol in marine engines. Regardless, it's best to drain it. I pulled five gallons of phase separated gas/water/ethanol/sludge out of my port tank this summer. Wound up with one gallon of filtered gas and used it in the lawn mower. Now it looks like the starboard tank needs some attention.
I use a siphon pump from Auto Zone. (Not the one from Harbor Freight -- that cheepo doesn't work.) Once you get the siphon going the fluid comes out pretty quickly. If your tank is under the floorboards you can gain access through the fuel gauge sender.
Old 09-17-12, 05:08 AM
GregH's Avatar
Super Moderator
Received 66 Upvotes on 61 Posts
For sure you should attempt to remove all the fuel.
Not sure what is available in your area but here our top premium fuel has no ethanol and since running this in my outboard and small motors have pretty much eliminated fuel related problems.
The difference in price is more than worth it.
Old 09-18-12, 10:36 AM
I
Do what I did with my jet boat when I first bought it. Get a clear hose that will fit thru the drain plug hole at bottom of transom, then take off the fuel pump/sender that goes down into tank (not the hose filler tube where you pump gas in tank because of the rise and losing prime).
Not put your clear hose thru the drain plug and into gas tank, then get behind/under drain plug and siphon it out into old gas tank(s). It helps alot if you have someone to watch the flow so you don't drink any gas!
Like GregH said, if you're lucky enough to have non ethanol gas closeby, make sure to use that in your outboard/inboards. See below to find good gas.
puregas.org
