GPS Runs off of House Current not off of 12Volt in car
vabear's Avatar
VA
10-07-12, 10:46 AM   #1
I have a TOM TOM 1 (301) and kit will charge and program off of household current but once I put it in the car and plug it into my power out let using the appropriate USB cable, she runs for about 30 minutes and then dies, after that I cannot restart her on 12volt current. I have tried several different cables with the same result, any suggestions (I know buy a new GPS).
chandler's Avatar
GA
10-07-12, 05:29 PM   #2
Are you sure your car outlet is hot? Have you plugged anything else in the outlet to see if it runs? I have a lighter socket (switch controlled) and a power point (always hot). How is yours set up. The fuse blew on my switch controlled socket recently for some reason. Replaced fuse and it is fine.
marksr's Avatar
TN
10-08-12, 05:03 AM   #3
My wife also has a TomTom although it's a different model. I agree with Larry that your car plug in might not be hot but it should also work longer than 30 minutes without being charged. I used her GPS in my truck once [no outlet] and it worked fine off of the internal battery. Probably on for about an hour but was turned off, didn't die.
I wonder if the battery is replaceable
retired painter/contractor avid DIYer
vabear's Avatar
VA
10-08-12, 05:51 AM   #4
No run on 12VDC
Outlet is hot, cell phone charges OK, I went both direct to the port and also tried using a USB hookup that plugs into port and takes up to two devices and still no go
chandler's Avatar
GA
10-08-12, 01:24 PM   #5
I know it is a longshot, but wifey picked up one of my bluetooth chargers when she went back to Albuquerque last week and although it fit her Atrix, it would not charge it. Do you have the correct charging cord with the correct usb end? Does the charger plug have an internal fuse that could have blown? some do.
Gunguy45's Avatar
Super Moderator
AZ
10-08-12, 02:12 PM   #6
Although many devices use the same plug....the wiring of the plug can be different. I think most newer models have agreed to the mini(?) USB standard....but not that long ago they all didn't.
Oops....well...looks like since 2006 they are on the standard.
I'd check if it charges from a USB port on a PC.
Vic
"I sometimes wonder how some people ever made it to adulthood..."
vabear's Avatar
VA
10-08-12, 04:15 PM   #7
No charge on 12VDC
She boots up and charges off of my PC.
chandler's Avatar
GA
10-08-12, 04:52 PM   #8
How 'bout the fuse in the plug head? Is there one?
