boats, starter bendix staying engaged
usmcmp74's Avatar
ME
10-14-12, 09:10 AM   #1
My friend has a lobster boat and he says when he startes the boat the starter stays engaged. He can turn of the key switch and the bendix still stays engaged untill he turns of the battery switch. When he turns the battery switch back on the bendix is no longer engaged untill he turns the key switch to the start possition again. Can somebody tell me whats up. Thanks.
chandler's Avatar
GA
10-14-12, 09:16 AM   #2
Welcome to the forums! Basically you have a sticking bendix gear. It could have been affected by salt water. Probably best to remove the starter and take the bendix off and clean it really good. You didn't say what motor it was on, nor the size. May not make a difference but it helps to have all the information we can.
usmcmp74's Avatar
ME
10-14-12, 09:19 AM   #3
Thanks!! I am going down to the boat to do a few tests to see whats up. He had a so called teck change the starter switch. I may have more info later today. Thanks again.
chandler's Avatar
GA
10-14-12, 09:30 AM   #4
New information may bring new suggestions. If the "tech" miswired the starter, he could have a hot wire jumpered to the wrong side causing the bendix to stay engaged. I'd check his wiring against factory wiring just to make sure. If the bendix falls back after you remove battery power, it may be the wiring indeed.
usmcmp74's Avatar
ME
10-14-12, 10:54 AM   #5
Water in starter.
Thanks Chandler. Im goind down to the boat at 3 EST. I think he said there was an old crysler motor in it ,and it has the old long starter with just one wire to it from the solinoid. I think as well that the other guy screwed up when he put in the new switch. I will let you know whats up. Thanks again.
usmcmp74's Avatar
ME
10-14-12, 01:38 PM   #6
Checked starter switch,OK. Checked solinoid,OK. Took out starter and stood on end ,and water started dripping out. Will replace starter. Problem solved, I hope!! Have a great week everybody!!!
chandler's Avatar
GA
10-14-12, 05:33 PM   #7
Glad you found what the potential problem is. C'mon back anytime!~
