Catamaran electrical power:
Old 10-07-13, 08:55 AM
D
My Cat is electically wired for 110v I now need to convert 110v to 220v to power the washing machine-how can I do this?
Old 10-07-13, 09:28 AM
Received 2,977 Votes on 2,686 Posts
Welcome to the forums from Africa
It may be easier and a lot less costly to try to get a 110/120v washer.
You can use an autoformer to raise the voltage. I specifically looked for units that could be inverter driven. You'll need to check the power requirements of your washer.
Auto Transformer 4500 VA 120/240 VAC
The following Xantrex unit is in limited supply and a bit on the costly side.
Xantrex Trace T240 Transformer
Step-Up/Step-Down Transformer 120-240-120 VAC | GoodBoatGear.com
Several listed here.
STEP UP/DOWN TRANSFORMERS - FOR SALE
Old 10-07-13, 09:31 AM
P
Received 1,572 Votes on 1,413 Posts
How do you get 110v on your boat? Is it from shore power, generator or inverter?
Old 10-07-13, 12:36 PM
D
I believe its been wired for shore power.
