water pump running often
Old 04-19-14, 04:49 AM
I have a 28 Regal cabin cruiser, I just changed the water pump because it had a leak. The pump is cycling on and off every 30 seconds, so I checked all the water hose fittings and no leaks and connections are all tight. O.k. now, I went into the engine room and turned off the water to the hot water heater and the pump stopped running. All the hot water lines are o.k. and not leaking. Could it be a bad pressure valve?
Old 04-19-14, 05:46 AM
chandler's Avatar
Received 9 Votes on 8 Posts
Welcome to the forums. It may be more of a pressure switch problem than a valve. Can your switch be adjusted or replaced?
Old 04-19-14, 05:54 AM
I'm not for sure where that switch would be? i'll need to look.
Old 04-19-14, 06:13 AM
P
Received 1,561 Votes on 1,404 Posts
Just to be clear you are talking about the domestic water pump and not an engine or bilge pump.
If turning off the hot water circuit stopped the cycling it sounds like a leak somewhere. Do you heat the water via the engines? A leak in that look can be difficult to spot.
Old 04-21-14, 04:19 AM
R
Received 1 Vote on 1 Post
Something is causing the system to lose pressure. Is there a leaking check valve that's allowing pressure to dissipate near the water heater?
