Bass Tracker Boat Storage quandary
I just purchased a 2002 Bass Tracker Pro 175. It has 2 storage compartments which are located on either side of the live well which have drop-in plastic boxes. These two compartments are also styrofoam lined with what appears to be drain holes in the side of them near the bottom. What the heck are these for, bait-well, cooler, storage, fish, what? Thanks, Lawdawg.
To use them as coolers. Some may use them for ice to ice their catch but around here they are mostly used for beer. I suppose you could put soda in there but I'd check the owners manual first to see if non-beer beverages can be carried in that compartment.
A regular cooler can be lifted out and the drain plug pulled. Built in coolers often have a drain hole so the melt water goes down into the bilge where the bilge pump can pump it overboard.
