We have this boat and the door lock has one those hook latch locks. On the door trim - left side - the latch plate for the hook to latch into is missing.
We can either try and fix the lock - get a new latch plate or I wanted to know if there is a extending bar lock I can buy that can span the width of the door and lock that way?
These boat door locks aren't very sturdy and worry someone could easily pop the door open with the stock locking mechanism so I'd like something more robust.
Yes, there are expanding/telescoping door locks. You didn't include the full doorway in your photo so we can't see where the other end of the bar will go. You'll just have to look at what locks are available and see if they will work for you.
I've usually modified something store bought or just fabricate something. Boats are such low volume and a wild variety of door styles it's doubtful someone makes a expanding lock.
In your case I might do something that pins into the side of the sliding door and frame. The pins in each end make it much harder to pry/slide out since you don't have a door jamb or seam for a traditional lock to slide into. It could use a standard padlock or you could build a shroud over the lock to make it more difficult to cut.
How is your door retained in the tracks? I'm curious how hard it would be for someone to just remove the door.
Not quite sure what you need.
Is the catch needed in the circled location ?
A stronger lock is nice to have but instead of them breaking the lock they'll just smash the door.
Hello,
My 2003 Johnson 115 outboard took a hit on a shallow oyster bar this month. It broke the entire skeg off and the ring behind the prop. I barely clipped the oyster bed with the end but it took the whole end off. No problem, I have insurance, right? Yeah, they said since it's an old motor, they will only pay 20% of parts and I have a $500 deductible. So they will pay $400 on a new $2000 lower unit but my deductible is more than that. So I'm just going to find a good lower unit and put it on myself since it's a quick job. I need to know what lower units are interchangeable. I see some on E-tecs and loopers and stuff that look similar but will they interchange? My model is j115plsrc
The bad part is that I would have cleared the oysters if I had moved over 4 feet either way. And I would have cleared them if I was going my normal speed, but I was going slow to accommodate the folks we were with in my slower aluminum boat. Oh well, it happens. I have the area marked on my gps and will steer clear of it now. Thanks for any info!
[img]https://cimg3.ibsrv.net/gimg/www.doityourselft.com-vbulletin/1500x2000/363380686_6838358286176473_75489507316007832_n_444967dc19324f55e910bc274afe737e31fdcad6.jpg[/img]
Read More
