Marine Die Hard Battery during storage goes to 72% even after recharging at 100%
Old 02-28-24, 07:30 AM
A
I have a Die Hard Battery for my boat, I leave it in my basement on a wooden shelf during storage, when I randomnly check it, it's showing 72% even after I recharge it fully, it has happened several times after recharging and checking it. I also noticed some liquid is coming out of the top cell caps. Is this normal? The battery is almost 1 year old this April. Is it defective?
Old 02-28-24, 10:04 AM
P
Received 2,181 Upvotes on 1,951 Posts
If liquid is coming out the top it may be over filled or could have been tipped. Check the electrolyte level of each cell.
I would check the battery with a load tester. That is the best way to tell you if it's bad or not. You can also get a rough idea with a multi meter to check the voltage. I very rarely trust the display on automatic chargers to determine charge level.
