470 mercruiser 1979
Old 11-14-01, 11:54 AM
470 mercruiser 1979
hi I am rebuilding a 470 mercruiser engine 1979 I changed and serviced the head and gaskets my problem is I still see oill in the water, i replace the seals on the water pump and the cam shaft.
some one told me is the oil cooler is that possible and where is located.
best regards
Old 11-15-01, 02:42 PM
BoatMech's Avatar
Have you pressure checked the cooling system,
i have seen a lot of deteroioration of the cylinder
liner aluminum which causes premature gasket failures.
Also is the weep hole to the water pump seals clear?
let me know. scott
Old 11-18-01, 01:20 PM
470 mercruiser
thanks for your reply
yes the weep hole is clear
any pssible the salt water gets into the oil ?
what are the possiblelity that the water gets into the oil
any thing i can do without stipping the engine again.
thanks you for your help and support
Old 11-21-01, 04:07 PM
BoatMech's Avatar
Your going to have to preassure check the cooling system.
If the closed system is OK then the exhaust manifold, elbow,
or gasket is leaking water into the engine thru the exhaust.
I hope you dont have to take it apart again. scott
Trackbacks are On
Pingbacks are On
Refbacks are On
