470 mercriuser
Old 12-05-01, 12:06 PM
G
Guest
470 mercriuser
hi scott thank you for the information.
i did check the presure of the water system there was no leak any where now the water in the oil is no lnger exist,but when i put the boat back in the water to give it a try the engine temperature came up after 10 minutes of starting
i put a new empela in the leg i do not know what i did wrong
can you advise please thank you for your support
Old 12-06-01, 03:39 PM
BoatMech's Avatar
Im glad to help. how hot did it get?
did you take apart the exhaust manifold
and riser assembly when you rebuilt the
engine?
If you changed the impeller correctly then
i would look at the riser to be blocked with rust.
try to blow thru the hose when the engine is off
and COLD.
let me know. S
Old 12-08-01, 10:32 AM
G
Guest
mercriuser 470
thanks again
yes i strip the manifold and clean the risers they clean now and i put new gaskets it start over heating after 20 minutes the water start coming to the water botle
Old 12-08-01, 02:37 PM
BoatMech's Avatar
twenty minutes??
is it in the water? or on the garden hose?
you shouldnt run it that long on the hose. It will
get hot unless you have a lot of water pressure.
Air pockets will form and the unit will not cool properly.
How hot is it getting? it will run at 180 to 190o F.
s
Old 12-10-01, 02:30 PM
G
Guest
470 mercriuser
hi again
sorry for the trouble .
yes the boat in the water and the temperature goes all the way sometimes now iam stuck i spent all this money and have no result
